AGT (Associate/FTFM Training) 8th May
Just a reminder that the AGT (Associate Group Training) for associates and Full Members(FTFM training) is on Sunday 8th Mayl. We look forward to seeing you.
No need to book, just turn up on the day.
Please re-join for 2022.
