AGT (Associate Group Training) 10th April
Just a reminder that the AGT (Associate Group Training) for associates and Full Members(FTFM training) is on Sunday 10th April. We look forward to seeing you.
No need to book, just turn up on the day.
Please re-join for 2022.
PLEASE NOTE: IF WEATHER CONDITIONS UNSAFE TO RIDE THEN WILL BE CANCELLED BY 6PM SATURDAY.
