Associate/Full Member Social Ride 22/05/22
May's social ride will be to the Scotsdales Garden Centre Fordham (CB7 5LQ).
Note: Colin is also running the Full Member ride this day from Sainsburys - my ride will park at the back of the car park, Colin will park on left hand side.
Destination: Scotsdales Garden Centre - we have been to this garden centre before which has good parking and large restaurant area. I have a really nice new route planned.
Distance: About 120 miles total.
Doug merrygold
Re: Associate/Full Member Social Ride 22/05/22
Post by Doug merrygold »
Hi mick &Alan,
Thanks for a great ride and good company good to see new and old friends,the weather was great,many thanks again Doug Maz x x :
Hi Doug. Great to see you and Audrey and John yesterday. Always a pleasure seeing you all turning up. Hope you can make June.
Best Regards. Mick and Alan.
Doug merrygold
Hi mick thanks for reply Maz enjoyed the day as well all being well see you on the next ride,Doug Maz .
