How to Improve Atlas Runs With Tablets | U4GM PoE 2
glico
Post by glico »
Popular build guides often push players toward expensive damage upgrades that consume most of their Path of Exile 2 Currency for a narrow gain in clear speed. In Expedition, that premium is frequently unnecessary. A well-timed weapon socket and a sensible Tablet route can deliver nearly the same farming momentum while leaving enough resources for resistance fixes, map access, and future crafting. The real goal is not chasing the largest tooltip number; it is keeping each encounter profitable from the first detonation to the final reward chest.
Expedition Pays Off When It Supports Your Entire Progression
Expedition is valuable because it connects immediate loot with long-term character growth. Tablets raise the ceiling of each run, while Soul Cores let players answer specific defensive or offensive problems without rebuilding every gear slot. That flexibility matters far more than a single lucky item drop.
The overlooked benefit is consistency. A character that clears moderate Tablet content quickly can collect artifacts, crafting materials, and replacement gear at a reliable pace. That income then funds the next upgrade, which makes stronger encounters safer instead of merely slower.
Test ordinary Atlas content before committing valuable Tablets to a route.
Upgrade the weapon when empowered monsters survive several full damage cycles.
Use defensive socket choices when repeated deaths erase the value of a difficult map.
Keep a reserve of Tablets for sessions when your build reaches a meaningful power spike.
Why Citaqualotl Is Better Than Its Reputation Suggests
Citaqualotl is an underused answer for elemental attack characters because players often focus only on premium penetration options. In a Martial Weapon, its increased elemental attack damage can produce a broad improvement across clearing and single-target damage. It becomes especially efficient during the transition from early mapping into serious Expedition farming, where enemies gain durability but expensive gear remains out of reach.
Many players dismiss it because the effect looks less specialized than Topotante's resistance penetration. That judgment changes when a build still lacks quality bases, finished passive support, or several strong modifiers elsewhere. Citaqualotl asks less from the rest of the setup, making it a better fit for limited-budget players who need dependable damage before chasing elite upgrades.
Choose the Socket That Solves the Current Problem
The choice is not permanent. Topotante is stronger when a developed elemental build already has high base damage and needs help against resistant targets. Citaqualotl is stronger when the character needs a cheaper, more universal step forward.
Choice Best stage Primary value Best player
Citaqualotl Early mapping Broad damage Budget farmer
Topotante Late mapping Resistance piercing Focused attacker
Jiquani Tablet testing Life recovery Risk averse player
For most developing characters, Citaqualotl wins the first investment decision because it improves every ordinary pack as well as empowered Expedition targets. Topotante becomes the better purchase only after the build can already clear efficiently and starts losing time specifically to tougher rare enemies.
Build a Tablet Route Around Survival, Not Pride
Tablets should act as a progression check rather than an automatic difficulty button. If Expedition monsters take too long to defeat, adding more encounter power only creates slower runs and greater repair pressure. A weapon upgrade or a Soul Core adjustment usually returns more value than forcing the next tier.
Jiquani offers a particularly useful safety valve through life recovery in a Martial Weapon, while defensive Citaqualotl and Tacati choices can patch elemental or chaos resistance gaps in armor. These smaller changes preserve a functional gear set and prevent a single weak stat from derailing a farming plan.
Spend POE 2 Currency Orbs on the bottleneck that actually limits each run, then raise Tablet difficulty only after that weakness is solved. Expedition becomes far more rewarding when every upgrade shortens downtime, protects the character, and feeds directly into the next round of endgame investment.
