Associate/Full Member Social Ride 20th October, 2024.
Hi all
Please join us for October's social ride - destination Dobbies Garden Centre, Rougham Road, Bury St. Edmunds. IP33 2RN.
NOTE: CANCELLATION: If weather forecast conditions bad, then will advise of cancellation by 6pm Saturday based on the overall conditions in forecast - e.g. 5 degrees or below with chance of freezing. Note: we've experienced conditions below this temp in micro climates/areas sheltered by trees causing freezing patches.
Note: Colin's Full Member ride is also starting at Sainsbury's same time. He'll be parked opposite the petrol station and I'll be at the back end of car park.
Note: If you have a friend interested in joining EAMG, then they can come along as a guest on the ride as long as they confirm with me first. Thanks.
Full tank of fuel - fuel available Sainsburys but no toilets. Toilets are at the BP garage Boreham interchange.
Distance: About 103 miles round trip - Approx.
Mick, Alan and Dave - please add mobiles to your contacts.
